Crack in neck heel
http://www-.luthiersforum.com/forum/viewtopic.php?f=10137&t=42978
Author:  dg_info [ Sat Mar 15, 2014 1:02 pm ]
Post subject:  Crack in neck heel
Hi all,
I have a crack in the neck heel of my electric guitar which was unfortunately probably caused when i was trying to re-align the neck. What would be the best way to glue? the crack is very small but i think goes up the side of the neck. Seems like it would be difficult to get glue into the crack. Does anyone know any clever tricks for this? thanks for any help, Dave
the guitar is about £200 in value but is one of my favourites so i'd like to fix the neck
Author:  johnparchem [ Sat Mar 15, 2014 1:22 pm ]
Post subject:  Re: Crack in neck heel
you can try clamping it and using thin CA. It will wick in the crack.
Author:  dg_info [ Sat Mar 15, 2014 1:49 pm ]
thanks for the reply
Author:  B. Howard [ Sun Mar 16, 2014 8:50 am ]
Crack looks like it heads toward the truss rod. Careful you don't lock it up with the CA.
Author:  dg_info [ Sun Mar 16, 2014 8:59 am ]
i think the crack is on the side away from truss rod but i will try and avoid gluing it..
Author:  dg_info [ Sat Apr 05, 2014 2:41 am ]
hi all,
The repair was done last week and so far it seems ok. Was a bit trickey to get the glue into the very small crack so I decided to drill 2 very small entry holes. This helped the glue wick into place. I had to do this about 6 times with a syringe. Found the glue very messy so a good work area is important. Also the very small syringe tip blocked quickly and had to use the medium tip. Some paper towels and tissue also was crucial after each gluage. Clamped carefully horizontally, vertically and left to dry for 24 hours then reassembled the geet for some careful testing. Did a bit of light sanding around the heel for an easier fit back onto the guitar body. Neck seems stable at the moment so good news and thanks again for the good advice.
pictures here:
http://s219.photobucket.com/user/DDviews/library/Guitar%20Neck%20Repair?sort=6&page=1
Author:  Tim Mullin [ Sat Apr 05, 2014 4:54 am ]
Looks like you used Chair Doctor Glue which is intended to swell wood with moisture before it cures. CA glue is quite different and probably would have been a better choice. Next time.
